Upgrading a Baba 30 to an unstayed mast?
JeffBobmen
Anyone have thoughts on upgrading an older boat (baba 30) to an unstayed mast?
From what I've been reading this is a big task and requires a lot of work (and $$$) to pull off. But maybe there is a DIY method to reinforce the hull to switch out to a carbon fiber unstayed mast?
European Bloke
829
I can't even begin to imagine what might go wrong. No, wait, I can.
I'm with Sloop.
If you do it please post photos after the first decent sail. Things have been quiet around here recently, you could fill a gap.
mgs
canoeman
1,271
322
maine
Sure, unstayed rigs have sailed around the world.
what exactly are you trying to accomplish with this mod?
I think the DIY method to reinforce the hull would be you doing the work yourself, no?
(For the record, I wouldn’t do it. If I wanted an unstayed rig I’d get a boat with an unstayed rig)
Bump-n-Grind
Get off my lawn.
15,375
4,255
Chesapeake Bay/Vail
ryley
743
Boston, MA
This would have been the kind of project that Eric Sponberg would have jumped all over. Unfortunately (for you, not for him) he's retired and sailing around the world.
El Borracho
Barkeeper’s Friend
7,262
3,195
Pacific Rim
Lemme guess…you just received the quote for replacing your 35 year old standing rigging, right? Then you thought “Why do I even need standing rigging?”
Rasputin22
Rasputin22
14,593
4,119
Bobmen,
    Take this to the Perry Facebook Fan Club page. Bob needs a good laugh these days...
longy
Overlord of Anarchy
7,496
1,604
San Diego
Just have to install a LARGE ring frame at the mast position to take all the loads from the deck level to the hull.
Raz'r
6,417
De Nile
And if you're going to lose the jib, don't forget you have to move the mast forward.
Yeah, no. Sell it and get a Nonsuch 30
Kevlar Edge
26
On the road
Sure and why don’t you convert it to deck stepped with a tabernacle. So you can easily lower it when you have to go under a low bridge. In all seriousness don’t do it
Look, they just stick the damn laser spar in a little fiberglass cup.  Scale it up to a trash can sized fiberglass cup, glue it to the cabin top, cut the hole, and Bob’s your uncle.
European Bloke
829
The trash can in the cabin is going to block the important area next to the stripper pole. You've got to think this shit through or these projects can get really complicated. Moving the stripper pole is not trivial.
MiddayGun
481
Yorkshire
Maybe the solution is just to use a laser mast, assuming you're already a keel stepped mast then you probably won't need to do any reinforcement at all. Though you will lose about half the sail area if you take it all the way down to the keel.
Slightly more seriously, some people do convert to Junk rigs and they're normally unstayed, might be a good place to start your search. But I doubt anyone does any real engineering, just overbuild the shit out of it.
