mckenzie.keith
Aspiring Anarchist
It looks like cat pumps are commonly used as one of the key components of small RO desalinators.
These systems pump water up to high pressure using the cat pump, and then some of the water goes through the membrane leaving salt behind. The fresh water passing through the membrane is no longer at high pressure. So there is no potential energy there. But the brine which is left behind is still at high pressure. One way to dispose of this is to let it pass through a restrictive valve. This dissipates the energy of the stream.
The clark pumps in Spectra watermakers don't operate this way, and they are able to avoid this waste of energy and are thus much more efficient in terms of gallons per kWh of energy used.
An idea I have been thinking about for a while is, why not take a conventional system with a cat pump, and add a second cat pump facing backwards and running in reverse to recover the energy? See this thread for example.
The second pump could be mechanically coupled to the first one but running at a slower speed (belts with different pulley sizes), or it could have a motor operating in regen and pushing electrical power back into the system. I think the belt coupling would be way more efficient as long as the speed ratio does not need adjusting.
It looks like the cat pumps do not have any internal gear reduction or anything. So I think this might work unless the inlet and discharge valves are one-way only, which they may well be.
I am sure people will say "why would you want to do this?" Well, you know, I am a curious type of person. I am just wondering if it is even remotely practical. Someone might pick up a cat pump from a pressure washer or something dirt cheap and use it for energy recovery. Spectra systems are quite expensive!
