V-15 grab rail rrpair
SockeyeUS119
I have to replace the grab rails on the vanguard. One got ripped off last summer. I 'll probably use wood because I' cheap and have free wood.
What is the good technique to put adequate backing in the hull to get the screws in?
PlayOne
Some people just keep the grab rails off altogether and put an eye strap or something to hold up the hiking strap bungee but it does make getting back into the boat a bit of a bear. The standard grab rails which are the same as the laser grab rails usually use an anchor not too dissimilar from a dry wall anchor. Any local laser dealer probably has some and they should be cheap and may work well for use with a wood rail.
