Kenny Dumas
Thanks Miff. Really good video
I just don't get why Alex is not sleeping. All the other skippers are saying they used the calm period to sleep a bit, some of them even feeling well rested. In 10knts of wind, instead of doing a video he should sleep 20 minutes at last to get ready for the front he is going to get into.
Last time he overslept he parked the boat on an island. Do we know if he's got a juicier shock watch this time?competitiveness. he mentioned that HB is not well suited to these conditions and he tries to make up for it by constantly trimming squeezing out every drop of performance. whether that is a wise decision mid to long term remains to be seen
This is her husband, Romain Attanasio on a non foiler.Pure-Best Western roughly 100 nM appartShe's closer to being French these days.![]()
And she is on a foiler Imoca and her fiancee isn't?And?
Thanks for that. I use the spreadsheet to convert the fleet boat positions for OpenCPN to gpx.Ah. Rankings downloads are back up. They were broken yesterday. Maybe the note I sent actually worked? (yeah, right. teams probably brought it to the website's attention)
Good idea to up certain polars for high performing boats. Are the newer boats a third quicker than the 2016 versions?Three routings with Omia, Apivia and Boss. Omia is at 110% of the last gen Imoca polars. Apivia and Boss at 135%.
Maybe on some points of sail, 2-3kts or possibly more has been mentioned. I recall someone generating polars for the 2016 foilers and posting those in that Vendee thread.Good idea to up certain polars for high performing boats. Are the newer boats a third quicker than the 2016 versions?
Glad to hear the mast didn't need to be pulledNice detail
(gtrans )We therefore had to find a spare hook (part which allows the sails to be hung at the top of the mast) loaned by the Banque Populaire team. Then clean the damaged area at the top of the mast: "We started by opening this crack to make a natural halyard outlet larger than before but without the carbon chips to avoid the risk of the halyard getting stuck in it," explains Sébastien Stéphant, technical director. “To secure this area, we made a small carbon plate that we glued around the opening to make a security band. " It is Simon Chevallier, expert composite of the team that is responsible for work on the area and the patch.“The mast builder validated the solution to make a sort of bandage. It is a lot of work because it takes five coats, the drying times of stratum and glue. The part is 5 millimeters thick at the thickest part. We started from the architects' plans and used a spare pole from the Charal team to cast it on the ground rather than at the top of the pole. We finished it last night and baked it all night, then glued it this morning. "
Sébastien Stéphant in turn climbed to the top of the mast to heat it up in order to speed up the drying time and allow the boat to resume sea this evening. “The new hook was delivered late yesterday afternoon. Everything has been installed, verified and working, ”he adds.
It takes a lot of effort to raise funds for two top-level foiling IMOCA campaigns, so its no surprise only one of the couple has a higher level boat. I say higher level as AT mentioned in an interview that Sam could win if she had a boat like his or Charal etc. There is still a good chance she will podium with a bit of luck.And she is on a foiler Imoca and her fiancee isn't?
https://en.wikipedia.org/wiki/Samantha_Davies_(sailor)
Are you seeing a news release?ok, so charal did have a problem
Agreed. Sams doing an awesome job. Fingers crossed for the next 24hrs.....good video here.Samantha is steaming along!!!
Thanks for that info. The Imoca 2016 polars are available and I use these, but am looking for the newest generation foilers. Upping the 2016 polars as @Hitchhiker posted upthread with a certain percentage is also possible, but hard to estimate to what level.Maybe on some points of sail, 2-3kts or possibly more has been mentioned. I recall someone generating polars for the 2016 foilers and posting those in that Vendee thread.
This Couple Is Sailing Around the World — Against Each Other
https://www.nytimes.com/2020/11/10/sports/sailing/sailing-vendee-globe-yachts.html
Sam Davies and Romain Attanasio have long supported each other in yacht races. Now, they are both in the Vendée Globe, a four-month race around the world.
By Chris Museler - Nov. 10, 2020, 10:54 a.m. ET
