southerncross
- 281
I am far from the best person to ask or trust an answer from. As already pointed out above, polars from a sail manufacturer are at best a first round approximation. But perhaps the most important part that the sail maker can't provide really useful guidance on are the cross-overs. There is no substitute for working these out on the boat.I am inclined to believe that that means that the winning team has to have polars that it itself established from experience, not from those provided by the designer, sailmaker or anyone else. And those polars need to take into account the load on the rig, if that is possible. Francis Vaughan or anyone else, is that possible? Or does it just has to be 'gut instinct' when to back off?
Source link?I read a piece from AKNobel that in the run to Lisbon they will be doing just that. Throwing stuff up, recording numbers (a lot!) so they can perhaps have those types of polars. I like that approach, but there is the "feel' factor that will also play in. The other point AK made was the four returning teams, Brunel, Mapfre, Vestas, and Dongfeng have that advantage and this is their way to jump start the process. They may not do well in that section, but the database they make could be gold.
Thanks for taking the time to reply Francis. If they have rig tension information wouldn't that show up potentially damaging loadings. As a simple example, repeated differences in loads in the windward components relative to one another (caps, and the intermediates to the roots of each successive spreader etc.), and the same in the leeward components. What I am trying to get at is whether there is a way DFRT or Mapfre could have known there was a problem before it happened. Maybe there was loading information but it wasn't collated and presented in a readily understandable form (e.g. stress at the upper starboard spreader repeatedly red zone!). I was surprised by the sail configuration that DFRT used that caused the problem (a masthead with a reefed main), but their speed polars presumably showed that it worked, otherwise they wouldn't have used it so much. And even North admitted that the boat was underpowered if they dropped down to the V1.That is where judgement and the instrumentation of the rig comes in. All of these boats carry rig tension instrumentation, that is intended to provide guidance. But even then it can only tell you that the last slam took you into the red zone. Judgement is needed to decide whether the next slam is going to take your rig past its limit.
Hi Bucc, the reason DFRT came fourth was a mistake / clusterfuck on a sailchange as they reentered the Solent. That took the from a close second to fourth. No lack of heart, no lack of 'sailing in the moment's. Just bad luck at an important part of the race.Because they had the chance to lead, and they finished fourth. Because they had enough talent on that boat to beat Mapfre, and they did not. Either you look at each race as a real race or not. We can argue long view or moment, but 3 other teams sailed in the moment. I can accept when a new team takes a race to tune or figure out how far to push and the say as such (TToP), but DF has been there done that and a brand new team beat them and Brunel, who had just had a week to get ready, beat them. I respect all the teams, but at the end of the day, we have our favorites. I expect DF to podium, they have the talent...so, I wish them well.
The VO65 has, AFAIK load cells on the chain plates and maybe forestay. No idea about backstay. Since the backstays have jumpers, it gets quite messy to work out what the precise loads on the mast are. It was indicated that they don't have the level of instrumentation that was common on the VO70. The problem with mast tube failures is that you don't really get a good idea of where the anomalous loads are just by looking at rig tensions. You can get an indication that the dynamic loads are getting higher as you drive the boat, but you can't really have any sort of absolute information. DFRT's mast failed due to deliberately applied loads bending the mast. A load cell at the mast step might have helped, but they really knew what they were doing, and had been warned they were outside the design regime for the mast. So they were not blind to what they were doing. Indeed, they knew the static strain the mast was under, as they had deliberately acted to put it there. The failure of the mast track bonding was predictable with that strain, and the failure of the mast tube not a huge step further. But carbon is a messy beast to predict and short of high tech tricks like bonding strain gauge wires into the layup of the mast, knowing exactly what was happening would have been difficult. But SS knew the tube had not been designed for that loading. And they told DFRT. All they get on the boat when driving are a set of warning lights that tell the helmsman they hit the red zone. Little more than a "please back off" warning. Trouble with those is they become a target, and a helmsman might decide to drive hard enough to just have the lights flickering on.If they have rig tension information wouldn't that show up potentially damaging loadings. As a simple example, repeated differences in loads in the windward components relative to one another (caps, and the intermediates to the roots of each successive spreader etc.), and the same in the leeward components. What I am trying to get at is whether there is a way DFRT or Mapfre could have known there was a problem before it happened.
No, I think they have heart, they have passion, and having lost races due to "things going wrong", I can feel for them.Hi Bucc, the reason DFRT came fourth was a mistake / clusterfuck on a sailchange as they reentered the Solent. That took the from a close second to fourth. No lack of heart, no lack of 'sailing in the moment's. Just bad luck at an important part of the race.
Obviously you have no way of knowing this, as it was not reported. Out of interest, would you think they have a lack of heart if they had finished second?
Bless you and thank you very much!www.rolexfastnetrace.com and its tracker crashed.
Live stream is at least here: https://www.facebook.com/pg/RoyalOceanRacingClub/videos/?ref=page_internal
And a tracker:www.rolexfastnetrace.com and its tracker crashed.
Okay, I did clarify so can you at least acknowledge that. I didn't word it right initially and good lord, we all have favorites. How they are presented, the public face...I don't connect to the team in the same as others, as you and since perception for many comes from what we see, I see a hell of a well sailed boat, yes I remember Black and Horace, but it took a long time for that story to emerge.He He - I have to laugh at some of the uninformed comments on the forum.
In the last race DFRT were criticised for 4 sail reaching and now Mapfre are being praised for it - make your minds up guys.
But the comment by Bucc that Dongfeng had no heart had me falling off my chair and to follow up with the "fact" they could have passed Mapfre in the RTIOW sprint an didn't because they "have no heart". It was a practice race my dear boy, they were pacing Mapfre so took the opportunity to try a couple of things to see if it was faster or slower - it was slower. This is part of Leg 0, the real stuff starts in October.
The Fastnet Race is a bit different and already it is DFRT & Mapfre that appear to be the front runners but only just. It will be interesting to see the positions when I wake up in the morning (close to midnight race time when the first tidal gate will have been negotiated and the tide will have turned (and turned back) or maybe Dee's Southerly position will pay off further out into the channel - who knows.
Don't you remember the footage of Charles thumping the wheel or jumping down onto the cockpit floor in the last race, or the efforts he made to learn enough Chinese to say the right thing when they got to the stage in Sanya?
Mo Heart - that's so funny.
SS
That's an interesting take. Would any team? How much is at stake, image wise, vs what you learn playing. Aknobel talked about throwing all kinds of sail plans up for the next "race" so perhaps none of them are taking it serious as a "gotta win". I just saw that Mapfre tacked over and yb has them as leader so at what point to you stop testing and start hitting the pedal. It is a level of sophistication above my scale for when I raced, I didn't hold back.bucc,
Be honest, did you really think Dongfeng Race Team would put every card on the Table for these Qualifying (Leg 0) Races? I still think they're holding back somewhat. Yes, these Boats are OD but depending on the configurations you can win or lose a lot. That's what happened with Dongfeng at the "Round the Island" Race.
