We need your help...
Glowfast are in the process of adding some individual labels to their Luminous Rope Clutch Labels sets and we'd like to hear from you.
So you don't have to buy custom sets (which can be a little pricey) we're bringing out a group of individual labels. This way you can add the one's that aren't on our standard set.
The most popular labels will go into production and should be ready for you to buy just after Christmas.
I've included an image of our standard set as a starting point and we've had some great suggestions already:
Mainsail
Spinnaker
Yankee Spinnaker
Yankee
Staysail
Topping Lift
Jib Halyard 1
Jib Halyard 2
Staysail Halyard
Traveller
Lead Car
Storm Jib
Pole Up 1
Pole Up 2
This is a place where what you suggest will make all the difference in what we produce, so please keep 'em coming!
Brita
WunHungLo
10
Add some numbered strips for outhaul position on the boom. Also a sheet with some large font single numbers on so that we can cut out the number and mark car positions for genoa/jib tracks and main traveler etc..
You might alo think about some labels for the interior for emergency situations or to avoid turning on the interior lights. We could then mark lockers where emergency gear is stowed. e.g. Medical kit; GRAB Bag, Tools, EPIRB, Fire Extinguisher, Call Sign.
It might also be useful to have a sheet of letters and numbers so that we can cut them out and make custom labels for whatever purpose.
Hi,
Numbered strips and the sheet of numbers and letters will go into the works with rest.
We already have the safety side of things covered - CLICK HERE to take a look or you can head to one of our stockists to find someone closer to home.
Brita
Port and Starboard versions of the halyard labels
Many boats don't refer to halyards as "xyz 1 or ABC 2" but as "Port spinnaker or Starboard Jib"
Mix and match them?
I would buy a set of the "-fucker" labels if they were ever produced B)
mrgnstrn
4
Herring Bay, MD
FIRST AID
LIFEVEST
EMERGENCY GEAR
and arrows, to point the way out of the cabin
and rolls of blank strips/tape to outline things like cabin steps. the draft stripe stuff may work, if it's thick enough to take the abuse of treading on in.
-m
