Veeger
Wow. This takes me on a journey in the way back machine. I grew up devouring all these pamphlets and materials. Piver, Cross, Jim Brown catalogs were the stuff of my dreams…
Thanks for sharing.
Thanks for sharing.
So how did she sail? What did you like and what needed improvement?Pretty cool for me to see the Brown Manta drawings (with fins on amas originally). I had one 10+ years ago and never found any info on the design around that time.
Polyester & ply with all the potential issues there (vs epoxy. Issues could've likely been minimized with above average maintenance over past years- most of my memories are peeling sheets of glass off areas of the decks with no end in sight). Would've preferred a central board of course but not enough to build one in myself at the time. Not too big and not too small, I did like the rear cockpit & simplicity of the boat solo but also it wasn't a big/spacious cabin or layout etc, certainly made me appreciate how much thought went into the center cockpit searunner as an optimized cruising design.Manta 34- So how did she sail? What did you like and what needed improvement?
Ugh. I've seen that peelfest on some DIY Opti's.Polyester & ply with all the potential issues there (vs epoxy. Issues could've likely been minimized with above average maintenance over past years- most of my memories are peeling sheets of glass off areas of the decks with no end in sight). Would've preferred a central board of course but not enough to build one in myself at the time. Not too big and not too small, I did like the rear cockpit & simplicity of the boat solo but also it wasn't a big/spacious cabin or layout etc, certainly made me appreciate how much thought went into the center cockpit searunner as an optimized cruising design.
