Go Bananas!
N'est pas nesessaire de demounter les rouesthanks! Can you still n’est the dolly on the trailer or do you have to remove the wheels?
il n'est pas nécessaire d'enlever les rouesN'est pas nesessaire de demounter les roues. In fact they are good shock absorbers when on the road. Thousands of kilometres have been done by many of us with this setup without issue.
Merci! That has to be the first time my native tongue is revealed by my autocorrect!il n'est pas nécessaire d'enlever les roues
7/10
I have raced against cats and the Weta is not really compatible because of the high drag at low speeds until it starts planing but it turns faster and easier because of the Daggerboard. Whereas cats have a more linear performance curve with little drag especially if flying a hull - but they are slow to turn. So the Weta is somewhere between a H14 and H16 .There is an active beach cat fleet racing every week during the (short) summer. Does anybody have experience racing against cats? Rating aside, is a weta competitive against a hobie 16, for instance?
My experience is the weta is competitive with a 29er in winds ABOVE 12KT. In low winds, it is competitive with the Lasers in up/down courses. Same vmg upwind and downwind. Frustrating to gybe all over the place and arrive at the mark at the same time as a ddw laser! And make sure you don't get inside of the Lasers ddw procession because there is now way in hell you will cross that line LOL.I have raced against cats and the Weta is not really compatible because of the high drag at low speeds until it starts planing but it turns faster and easier because of the Daggerboard. Whereas cats have a more linear performance curve with little drag especially if flying a hull - but they are slow to turn. So the Weta is somewhere between a H14 and H16 .
in Australia, the handicap Yardsticks for cats are calculated using the SCHRS formula which obviously the Weta doesn’t fit into because it’s not a cat. So we have campaigned for a long time to get off the cat list and onto the dinghy list which is based on National and international data. We finally managed it this year with a trial rating, slightly slower than the B14.
I normally race in a monohull dinghy fleet where the Weta is very competitive with other skiffs like the B14 and 29er as well as fast monos like the FD.
You can find the Australian Yardstick lists here https://www.sailingresources.org.au/class-assoc/yardsticks/
Yes, sort of. If the wind is at least in double digits, the Weta will blow away any Hobie 14 or 14 turbo. The H16 is a different story - it's simply faster upwind than the Weta. Downwind with the screecher out and sails sheeted in tight and the boat brought up hard on the wind, you can get past them. But you have to sail a different course and try to take advantage of the Weta's much quicker turning ability. Sail it more like a skiff and you can be competitive.Merci! That has to be the first time my native tongue is revealed by my autocorrect!
We have a local brainiac cat sailor that massaged the SCHRS formula last summer to come up with a rating for the Weta. He used the beam of just the vaka and one ama. He also compensated for the other ama by adding a trapeze. I can't remember the rating he came up with, 1.225? 1.252? I'll have to ask him. We only tried it out twice, sailing against Prindle 19s, but it was pretty accurate on those two occasions. Hopefully, this summer we can test and tweak it some more.SCHRS formula
Not much difference between this “formula” and plucking a number out of thin air. SCHRS is for cats.We have a local brainiac cat sailor that massaged the SCHRS formula last summer to come up with a rating for the Weta. He used the beam of just the vaka and one ama. He also compensated for the other ama by adding a trapeze. I can't remember the rating he came up with, 1.225? 1.252? I'll have to ask him. We only tried it out twice, sailing against Prindle 19s, but it was pretty accurate on those two occasions. Hopefully, this summer we can test and tweak it some more.
I find your disparagement curious. Since there is no rating system for trimarans and the local beach cats use SCHRS, one has to make do with what is available. You race against dinghy, I race against beach cats. IMO my friend's massaging of the SCHRS formula to try and make it work for a trimaran is quite a bit more effective than "plucking a number out of thin air." The Weta has been around for over 15 years and no good handicap number has ever been devised for it. At least here, locally, the beach cat fleet is making an effort to include me in their races.Not much difference between this “formula” and plucking a number out of thin air. SCHRS is for cats.
Don’t make the same mistake I did and over tighten the tramps. It makes inserting the aka’s arms into the hull very difficult.How tight are your trampolines? Having sailed beach cats where tramp tension typically adds stiffness to the platform, I am inclined to put a lot of tension. Shall I worry about putting stress on the beams?
I learned my lesson this time, and tightened the tramps with the akas inserted...Don’t make the same mistake I did and over tighten the tramps. It makes inserting the aka’s arms into the hull very difficult.
^this. As for the line attaching the tramps and amas to the vaka, I tighten those as much as I can and check them occasionally while out sailing to re-tighten if necessary.tightened the tramps with the akas inserted...
If you need to replace the line that ties the trampolines to the boat, how do you do this? The fabric seam/pocket is so tight I can't string a replacement line.^this. As for the line attaching the tramps and amas to the vaka, I tighten those as much as I can and check them occasionally while out sailing to re-tighten if necessary.
I accidentally pulled the line out of the tramp derigging the boat one time so I used the stainless shroud wire to fish the line back through.If you need to replace the line that ties the trampolines to the boat, how do you do this? The fabric seam/pocket is so tight I can't string a replacement line.
I was able to use rigging tape to tape the new line to the old one and pull. If your tramp is cooked by the FL sub, this may get tricky.If you need to replace the line that ties the trampolines to the boat, how do you do this? The fabric seam/pocket is so tight I can't string a replacement line.
