SloopJonB
The 37 had a wedge cabin top - this one doesn't, it's a flush deck
IIRC the sinking off Florida was a suicide attempt...If you ever read Webb Chiles book about trying to sail his Ericson 37 around the world, or if you remember when the Ericson 46 Chiquita sank, you will know that these boats have a potentially fatal problem: they were laid up in two halves, and then glassed together down the centerline on the inside, a very sharp inside angle along the bottom and aft edge of the keel. Those centerline laminations were prone to failure resulting in a long crack and water coming up all around the ballast. They looked perfect from the inside, but shoddy workmanship was completely hidden from later inspection.
I'm not so sure about that. Take a look at the US Navy Salvors' tables: a 2 inch hole 2 feet below waterline lets water in at 111 gallons per minute, or 6,600 gallons per hour.One pump could keep up with a failed thru hull, much less two or more.
Unless, as is likely, there was the usual clutter inside the boat that kept clogging the pumps, and the story does not mention that part.
Them's some terrifying numbers....Ah, something new to post in front of the urinals at my yacht club. Thank you!
Well, if you are a boomer and you don't own your own home in Australia, then either you gave it to your ex wife, poured all your money into the pokies and the local pubs till or you are a generational loser. That shitbox sank because of lack of maintenance. Every creek in the country has a few of these.yeah sorry about that, I do feel for these guys. they're not in a good spot.
Australia is a country where growing old without owning land is not a viable option
really?Australia is a country where growing old without owning land is not a viable option
I was going to call BS on the $800 a week couple amount. Googled it and F-me it's pretty much right. Not bad for doing nothing.really?
Weekly pension up to $800 for a couple. You can rent a two bedroom apartment in Cairns for less than $500/wk, 1 bedroom for less than $300.
Health services - mostly free or low cost.
nostalgia for the IOR?Why is a live-a-board shitbox sinking at its mooring even newsworthy?
I spent most of my money on boats, broads & booze.Well, if you are a boomer and you don't own your own home in Australia, then either you gave it to your ex wife, poured all your money into the pokies and the local pubs till or you are a generational loser
It's not.Googled it and F-me it's pretty much right. Not bad for doing nothing.
It's not.
And yeah. F- you.
Per fortnight | Single | Couple each | Couple combined | Couple apart due to ill health |
Maximum basic rate | $971.50 | $732.30 | $1464.60 | $971.50 |
Maximum Pension Supplement | $78.40 | $59.10 | $118.20 | $78.40 |
Energy Supplement | $14.10 | $10.60 | $21.20 | $14.10 |
Total | $1064.00 | $802.00 | $1604.00 | $1064.00 |
