darcy.craig
- 0
I like that rudder. Obviously built for high speed.
Only two boats made it out of the Abbot shed before they were burned / chased out. If I recall correctly. Even 203 Brads boat just missed getting BBQ'ed as he had just moved it the day before if I remember his story correctly.when was the last one built? Abbot?
Since men have put to sea... with women.Since when has 'ability to shag' been the defining metric of useful cabin ?
That seems completely backward. The foam core should be waterline down with the balsa core above the waterline.U20's were built primarily with balsa core - however Ron Moore built the first 30 hulls and I know that mine had balsa water line down and foam water line up in the hull. And the deck had balsa core.
I know that there are a few other random U20's that have foam coreing at some level.
Jim Antrim has been consulted pretty much by every builder to ensure they have the right cook book plan for the layup and I am a firm believer that this has created solid consistant boats built by all the different builders over the years. Jim gets excited every time the U20 demand pulls another builder into the process.
Balsa has a higher crush/dent resistence on a boat expected to be dry sailed balsa water line down makes more sense than water line upThat seems completely backward. The foam core should be waterline down with the balsa core above the waterline.U20's were built primarily with balsa core - however Ron Moore built the first 30 hulls and I know that mine had balsa water line down and foam water line up in the hull. And the deck had balsa core.
