Twenty? It was full on from the first one.Its two gadflies!
Didn't really come as a surprise, did it? I say 20 posts before it's a full-on foiling shit fight.
Doesn't matter I don't think it'll fly.Personally, it seems bizarre to me that they do not use active controls, but instead use these very unstable passive controls.
Generally, you don't have cavitation until speed is well over 40 knots. The G4 probably won't go that fast......Question I have is , I read or heard the the high speed Americas cup boats were really hard on the foils , after every day the foils had to be pulled out and repaired / tidied up due to the abrasive reaction due to cavitation (air bubbles) at high speed . How the hell are you going to maintain the foils on a boat like that . If you were to cross an ocean ect , by the time you got half way you would have no foils left?
You don't know what you're talking about. She dropped off the foils because, probably, it was fairly light air-all foilers do that from time to time. There was no sudden stop as the previous "expert" said was a characteristic of these kind of foils. "Bottoming out" is when a foiler is in short,steep seas and can't platform or contour the waves. It's experienced by the foiler staying on foils but having waves strike the bottom(and is slow)-hence "bottoming out". Having a foiler is no substitute for basic seamanship-every foiler has conditions that aren't ideal and/or that require not flying. Even in those conditions the foils help with the motion and with pitch stability.Upwind flat water. Ho hum. And even then, the GC32 bottomed out a few times. That's not good.
LR Franken45's likely have active control on the rudder.Luna Rosa AC 45's on UptiP foils:
When you say active , do you mean electronic or manual control via electronic/hydraulic control of the rudder AOI? Do have a link for either one or the other?LR Franken45's likely have active control on the rudder.Luna Rosa AC 45's on UptiP foils:
AC62's will have active rudder trim as well.
Does the GunBoat? I guess it's a rather bold experiment - but they are smart people building these boats.
Trim'able while racing - but manual. Something the AC72's did not allow but the AC62's will.When you say active , do you mean electronic or manual control via electronic/hydraulic control of the rudder AOI? Do have a link for either one or the other?LR Franken45's likely have active control on the rudder.Luna Rosa AC 45's on UptiP foils:
As far as I know the GC32 and FP have manual adjustment of the rudder AOI.
Locust!Twenty? It was full on from the first one.Its two gadflies!
I still think I have the most correct (revised) answer: its a swarm of gadflies!
But don't they move on?Locust!Twenty? It was full on from the first one.Its two gadflies!
