It's a metal alloy that's one vowel inferior to aluminium!WHAT'S ALUMINUM?![]()
Actually that is not aluminum or aluminium for that matter. Every part of the boat you see in that photo is .125" Titanium as well as the hull plating. Keelson may be 1/4" (instead of 3/8") as Jim didn't like the big difference between the thickness of the two plates for welding. Lots of pitfalls welding with Ti!Bett's method of construction for aluminum.
It's the leading edge D-Box for a J3 Super Cub. Easy one.
J3 = Piper CubIt's the leading edge D-Box for a J3 Super Cub. Easy one.
That has got to a pricey build!Actually that is not aluminum or aluminium for that matter. Every part of the boat you see in that photo is .125" Titanium as well as the hull plating. Keelson may be 1/4" (instead of 3/8") as Jim didn't like the big difference between the thickness of the two plates for welding. Lots of pitfalls welding with Ti!
Ya think?That has got to a pricey build!
