What's in your arsenal??
Point Break
5,233
Long Beach, California
^ Unfortunately, I've been in them a few times.
Fascinating machine. How does that idea even come to mind?
Spinning magnets and picture taking.... WTF?
A few times….I wish. Got another one next month. Fortunately several of the providers around here have the coolest newest critters and the scanning time is significantly less. I don’t mind the tube etc….it’s laying perfectly still for long periods……that is a PIA. I had one a few years ago that was 1.5 hours. So the reduced scanning time makes them much less onerous.
Point Break
5,233
The noise is somewhat rhythmic and I was able to tune out but I was only in for ankle and knee stuff.
But 1.5 hours....
Yep. I could care less about the confinement or noise but…..it’s SO hard to lay still for that long. Can’t go to sleep because I’d twitch or move a little so gotta stay awake….and immobile. 🙄
  • Like
Reactions: mad
Virgulino Ferreira
1,867
Brazil
mad
https://www.independent.co.uk/news/world/americas/brazil-lawyer-death-mri-gun-b2279514.html
A lawyer was accidentally shot by his own gun after he failed to remove it before going into hospital MRI scanning room.
Leandro Mathias de Novaes took his mother for a scan at Laboratorio Cura in São Paulo, Brazil, on 16 January, Jam Press reports.
The 40-year-old is said to have failed to tell hospital workers that he had a gun on him after being told to remove all metal objects before entering the scanning room.
The magnetic field from the MRI scanner pulled the pro-gun lawyer’s weapon from his waistband and it went off, shooting him in the tummy.
He passed away on 6 February after battling for his life in at the São Luiz Morumbi Hospital.
mad
To put a barrel shorter than 18 inches on a shotgun you have to file for a tax stamp to create a "short barreled shotgun".
I'll be honest I think it is complete crap that I have to ask permission from the ATF to do it, but I follow the law and paid $200.
24 inches is the minimum allowed in the UK, not sure I'd really want one below 18 inches though.
2,212
Apart from slightly easier to carry, whats the advantage of chopping off 6 inches of barrel?
The other, more historical reason would be that it's easier to swing around and point the opposite direction if that should suddenly become necessary in some godforsaken frozen trench in Europe. Hey, it's happened. So a potentially useful militia weapon.
Tom,
? are you thinking about a suppressor for the new assault twenty two ?
, better than flowers ,
I'm looking into non-scary bling but for those who DO have thoughts about suppressed .22 assault weapons,
Velocities of Subsonic & Suppressor Ready .22 Cartridges Fired in Pistols
As can be seen from the chart, all of the rounds tested were reliably subsonic from the pistols tested. While the speed of sound varies with temperature, even at 40 degrees below zero, the speed of sound is above 1000 fps. As the temperature rises, so does the speed of sound. At freezing, it is 1087 fps. At 70 degrees Fahrenheit, it is 1128 fps. At 100 degrees F, it is 1159 fps. Atmospheric pressure has little effect on the speed of sound. As relative humidity increases, there is a slight increase in the speed of sound, just a few fps. It is expected few shots will be fired from a suppressed .22 pistol at temperatures lower than 40 below zero.
Yes. Yes, that is expected. Because if it's 40 below, chances are no one is around to hear it. Or fire it.
Interesting that the slowest ones were also loudest.
  • Like
Reactions: mad
2,212
Very valid point
Too bad no one showed up to make it in the only Supreme Court gun case of the 20th century.
In the absence of any evidence tending to show that possession or use of a 'shotgun having a barrel of less than eighteen inches in length' at this time has some reasonable relationship to the preservation or efficiency of a well regulated militia, we cannot say that the Second Amendment guarantees the right to keep and bear such an instrument.
The absence of evidence was because no one showed up to argue for the defense and the prosecutors certainly knew about trench brooms but weren't going to bring them up. Certain Justices also had reasons to know, but stuff they know isn't evidence.
