mckenzie.keith
Aspiring Anarchist
- Thread starter
- #121
So just to recap.
1) Bottom and prop were still fairly clean, according to the divers I hired to clean the bottom and prop. They cleaned it again anyway.
2) Exhaust elbow was supposedly cleaned by mechanics in San Diego which is too recently for the elbow to be clogged already. I am assuming it is good.
3) No signs of black smoke or black junk in exhaust water at 2900 RPM.
4) Just confirmed throttle (governor whatever) lever on the engine can be driven all the way to the full-throttle stop by the cockpit "throttle" control. So it is not a lack of travel problem.
5) Tach is reasonably accurate. Less than 50 RPM off as far as I can tell. This was verified with a handheld digital tach on the crankshaft pulley or harmonic balancer or whatever that big wheel is connected to the crankshaft on the non-drive end.
6) The current pitch (13 inches) is much higher than what flexofold personnel are recommending. Prop is also too small in their opinion (17 inch diameter is too small).
7) As a place to swim, Ventura harbor is not terribly inviting. But I was only in the water for like a minute to measure for the prop clearance.
So, I think it is now clear that the boat is over-propped and that is the only really plausible explanation left for why I cannot achieve 3800 RPM.
There is slightly over 12 inches from center of prop shaft to bottom of hull, so there is room for an 18 inch prop. It will be a lot cheaper for me to buy two new 18 inch blades from flexofold than to buy a 3 blade prop. I am not for sure yet on that decision but I think I will probably go with the two-blade 18 to save money, unless the flexofold guys are fairly adamant that I should go with three blades. I can also keep the old blades as spares.
I am most grateful to you all for sharing your knowledge, wisdom and experience, humor etc.
