paps49
OK that seems to be settled, Hung you have your rig parameters.
What are the latest thoughts on propulsion??
electric.
okay, now that you've stopped laughing, I'm dead serious.
I looked up the Steyr hybrid diesels but the lowest up rating was 55 which I think is too much for this boat. A totally electric system would probably not last long enough for a windless overnighter in any area with strong currents. There has to be a hybrid type system somewhere that would work. In the Puget Sound area solar cells would't work too well.2009, thats a given! ;-)
Any brand in mind?
/J
electric.
Well, since this is pretty much fantasy, here's how I'd propose it:
Full electric propulsion with diesel/electric generator. No hybrids. The evolutionary branch of hybrids is a dead end.
The biggest issue is batteries. In cars, you're limited by space. On this boat, the sump could be considered an ideal spot to load up on batteries. The battery technology is set to change over the next 5-10 years to where this really will not be an issue.
With that said, we could design a full electric propulsion system and pick a spot on the boat that says 'batteries go here' and 'genset goes here'. That will free us up to put the drivetrain in place as-built.
In case you couldn't tell, I'm pretty psyched about the prospects for electric drives. There is so much potential for this to have a humongous impact on everything we do. I could be wrong and I'm old enough to not give a shit if I am.
But I don't think I'm wrong.
If you have a genset and batteries and an electric motor you have a hybrid system don't you? There are many different kinds of hybrid systems, it depends on how you mix and match the elements. A true diesel-electric system runs the genset all the time at it's sweet spot to power the drive motor and doesn't run on battery power at all. Many people think they are more efficient than straight diesel propulsion but in truth by the time you factor in the various losses they are a bit less efficient.Well, since this is pretty much fantasy, here's how I'd propose it:
Now you've done it! Talking about a Whispergen. I've lusted after one forever. Even made a deal that the Admiral could get a puppy if I got a Whispergen. The problem for this application is that the Whispergen only puts out 1500 amps @ 12V per 24 hours. Great for a house battery bank but not for serious electrical consumption like propulsion.If you have a genset and batteries and an electric motor you have a hybrid system don't you? There are many different kinds of hybrid systems, it depends on how you mix and match the elements. A true diesel-electric system runs the genset all the time at it's sweet spot to power the drive motor and doesn't run on battery power at all. Many people think they are more efficient than straight diesel propulsion but in truth by the time you factor in the various losses they are a bit less efficient.Well, since this is pretty much fantasy, here's how I'd propose it:
The cool thing about the Steyr units is you can run them in several different modes: diesel only, diesel + electric boost, electric only and generator mode plus the motor acts as the starter if you want. It only adds 15" or so to the base engine, before the gearbox. But as I stated earlier the lowest up rating is 55.
Maybe a Whispergen generator would work for the system you are proposing. Worth looking into.
I'd love to have a solar cell setup if it you could get the required power from a small number of cells but plastering them all over the boat would have severe aesthetic consequences IMO.
Genset, big battery bank, & electric motor work for me.
Welcome. You won't need a winch for the main on this boat. It's almost identical to the size of a Mumm/Farr 30. Blocks will be fine, particularly with a fine trim cascade of blocks off the gross trim.
Second that. Its a fantasy boat and the primary purpose is daysailer/overnight. So why not go for all electric, put in some built in panels on the coach roof and go for Li Ion batteries to run the drive unit and a separate house bank. I would be against the genset. With the pupose being daysailer why would you need the genset?Well, since this is pretty much fantasy, here's how I'd propose it:
