Epoxy is best handled at room tempI'm going to be building a PT11 as soon as the kit arrives from CLC. I'm planning to build it in my unheated garage...which I understand may be a problem with epoxy. Any tips and/or things to avoid during the build process?
If you decide to use a heater … your project may cycle hot, cold with heater use .. remember the phenomenon of out gassingI'm going to be building a PT11 as soon as the kit arrives from CLC. I'm planning to build it in my unheated garage...which I understand may be a problem with epoxy. Any tips and/or things to avoid during the build process?
or at least the den... seriously folks ...Why has nobody suggested "Living Room"?
https://www.westsystem.com/instruction-2/epoxy-basics/cold-temperature-bonding/I'm going to be building a PT11 as soon as the kit arrives from CLC. I'm planning to build it in my unheated garage...which I understand may be a problem with epoxy. Any tips and/or things to avoid during the build process?
