Work Bench for the Man Cave....
P_Wop
4,830
Bay Area, CA
1. It seems obvious, but I did see someone do it 100% wrong.  He wondered why it wasn't working, then gave himself a bit of flat-head syndrome.
2. Radiusing the aft corners really helps.
3. 1/16" is as close as I would go, to accommodate imperfections (ha!) in your garage floor when the wheels aren't in use. To help the lift, mount the dowel bar about a third or half way up the legs so your arms are straight when you''ve lifted the end..
Also, when you install a heavy bench vise it helps to put it at the wheel end.  Don't ask me how I know that one.
EDIT: the drawing says 1/6" or 1/8".  That should have been 1/16" or 1/8" of course.
I've considered it, and my side cabinets have a sacrificial ply top than can be swapped out, but I like the basic nature of this one. I can live with it's little imperfections, as I put most of them there. (all except for the time the wife was cutting holes in canvas for snaps, without putting down a sacrificial piece of ply. There's an area of the top that looks like it had chickenpox)
This is a good material for bench tops
https://sylvan-products.com/product/resin-form-film-faced-formply/
or you can use cheap white melamine. Get a pine core if they have it.
Raz'r
6,395
De Nile
Ok, my garage has been invaded by all my boat shit, since the boat is empty and in the yard. So I have no room for anything. The bench is in use for 2 things right now: Laying up some saddles for carrying the spin poles mounted to the deck, and the E-Rudder is in the vise (cant see the vise, the rudder is in the back) so that I can lay-up the rudder head for the tiller socket.  F-you guys with pristine work spaces...   B) IMG_1026.jpg
warbird
1,516
lake michigan
F-you guys with pristine work spaces...   B) View attachment 353865
I moved 2 years ago to a much smaller space. I bought some cheap furniture dollys and I put  2 totes on each. They roll out from under a benchtop amd give easy access. Thus i have auto lubes,  wax, etc in one place. Boat paint, wax, compound, supplies in another.  An epoxy and materials, etc all under  work surface.  I still get spread out and messy but I can stow it pretty quickly. 15851943285194970478197302046053.jpg
sledracr
1,193
PNW, ex-SoCal
Mine's not movable, by design.  Wanted a bench that was solid enough to do things on without worrying about wiggling.
10' on the long side, 6' on the "L", built with 2x6 legs 2x4 framing for the top and covered with 1" ply... and then lag-bolted into studs in the garage wall.  The height was set to be the same as the table for the radial-arm saw (out of view) at the left end.
There are a variety of machines mounted to the top of this thing and it is rock solid.  *IF* I wanted to move it, I could pull out a half-dozen lag bolts and drag it out into the other bay of the garage.... but have never yet felt the need.
Raz'r
6,395
De Nile
I moved 2 years ago to a much smaller space. I bought some cheap furniture dollys and I put  2 totes on each. They roll out from under a benchtop amd give easy access. Thus i have auto lubes,  wax, etc in one place. Boat paint, wax, compound, supplies in another.  An epoxy and materials, etc all under  work surface.  I still get spread out and messy but I can stow it pretty quickly. View attachment 353868
Nice
Rushman
FIIGS
2,567
283
Melbourne, Aust
Let the mocking begin
Note that a 6 x 4 trailer usually inhabits this area too
(hints on how to get the image the right way up would be good to)
warbird
1,516
lake michigan
My goal , not yet realized, is to have no open dust collecting shelves. The cheap plastic totes keep the dust down, the furniture dollys make it all easy access.
peragrin
84
I don't have much room so I have a smallish fixed bench then I built/building  the below.  A pair of modern builder saw horses that are collapsible. Fit a frame of 2x4to whatever length.  (Mine is 4' x 42" by choice) I was going to put a top on it but it is very useful with out the top.
It stores flat, the open layout is great for clamping, bonus the saw horses are then useful for other projects anyways.
Grande Mastere Dreade
Snag's spellchecker
Ok, my garage has been invaded by all my boat shit, since the boat is empty and in the yard. So I have no room for anything. The bench is in use for 2 things right now: Laying up some saddles for carrying the spin poles mounted to the deck, and the E-Rudder is in the vise (cant see the vise, the rudder is in the back) so that I can lay-up the rudder head for the tiller socket.  F-you guys with pristine work spaces...   B) View attachment 353865
what's that tool on the left, mini-planer ?
