he b gb
Go Team Australia, I’m in total awe of Rod Waterhouse.He must be in (or close to) his sixties now! That finish yesterday shows extreme fitness ( and skill) for someone in that age group.
About 160 miles in 18.5 hrs.=8.6 mph upwind double trapped, it's blowing 20-30 in 6 to 10's on a F18.Rod is just a big kid.
the team with the C2 that fractured found their spare boat had fractured in the same place, so trailered it to the start of the next leg, I haven’t heard of this being a problem with C2’s and wondering if it was how they were trailered or handled.So 10 of the 13 boats are Nacra;s. And 8 of those are the newer Evolution model, while two are the older Infusion model (which there are several variations of)
The boat which suffered the big ugly hull fracture was the lone Goodall C2.
The top 5 boats (the four who finished yesterday, plus Team Rudee's (Randy Smyth)) are all Nacra Evolutions
Not a bad idea. I don't have time to go through the F18 Class rules at the moment, but the Worrell boats are all required to comply with F18 regs down to the dot. So if the F18 requires a sail of a maximum size and does not stipulate a minimum, that could certainly work.F16 sail?
EVERY year the rhumb line guys get worked on this leg. Inside is sketchy but definitely the way to go.From the tracking map it looks like the Netherlands boat closest to shore is lifted and ahead, whilst the boats closer to the rumb line are headed. This may be a year where the rumb line guys get worked. The captain of the Dutch team, Mr. Loos has won many tittles in the past. I was wondering why they were at the back before this. They are only 1/3 of the way so far and there are weird weather patterns about, but maybe team Holland will win this leg.
It was imposed on the Jensen to Cocoa leg.http://kws.kattack.com/WPlayer/WPosDisplay.aspx?FeedID=1909
Also has a leaderboard shows some real time display during the legs. The overall leaderboard, though, doesn't seem to show (right now) the penalties imposed for the DNF leg.
The 8 times I've raced that leg the rhumb line never paid. I've done the rhumb, split between the two (that was the absolute worst) and run the inside and the inside always worked. The Fleet may "take" the rhumbline ,and they often do, but that doesn't mean it's the fastest. Herd mentality is a bitch.Almost 14 hours later and the leaders are neck and neck reaching along at 8 knots. Rudees, and Australia.
The 2 times i sailed this leg, the fleet took the rhumb line. Was early 80's.
That is a weird approach at night. You feel farther offshore and North of what you truly are, and the pier helps block the finish a bit adding to the confusion.During the T500, I never came into Tybee at night. Can't imagine trying to cross the Tybee Triangle at night with those deep-ass F18 boards. Even during the day it sneaks up on you.
