Thanks Zonk and Longy,The alt attaches to the bracket with a long bolt. Yours has broken off the threaded end. The 'sleeve/insert' you can see in the aft alt tang is to allow for slight differences in the spacers andengine mounts. It is meant to slide towards/into the alt arm to take out any gap in the installation. It is common to tap this sleeve out a bit prior to installation of a alt to get enuff gap to easily install the fiddly spacers. A new alt comes with the sleeve un-installed. The forward alt arm does not have this sleeve.
Removal - I'd concentrate on applying rotation, the alt arm is just cast aluminum. I suspect the bolt failed at the start of thread & still goes almost all the way thru the system. Stick a probe in the hole & measure depth.
The mystery is: how is this thing still welded on so tight? I can barely rotate the alternator itself, the bolt is seemingly welded to the alternator tab. All this with no nut on the back to hold tension.
What is it, that this bolt is threaded into that's gripping so perfectly.
Back to the boat on Sunday morning to find out, I hope
